I have a Simply Automated UMI-32 I/O module controlling my garage doors.
The module works good and I have assigned a scene switch in my kitchen to control opening and closing one of the doors as well as created a couple buttons that send an "on" link command that I use via Haiku.
The issue that I am having is that the "Turn all off" command that I execute in Haiku is causing both doors to open.
I assume it is because I have the actuation tied to a "link" and the "all off" command sends all links a command. I have named all of my links and units as required for the HAI HLC format. I have read conflicting things, however, about link assignments for non-HAI units. My controller actuates/displays my light units status pretty well (a glitch every now and then in showing the correct status).
Is there a "link range" that units like this I/O unit are supposed to be named so that blanket light unit commands won't actuate the I/O module?
