AutomatedOutlet
For the hardwired systems, are the devices / controllers / software themselves significantly more expensive, or is it just having to run the low voltage control wires?
We'll be carrying the LiteJet stuff soon so I have seen pricing. Pricing of course depends on configuration but you can plan on about $100 per device.
We also carry the Lightolier MultiSet Pro hardwired system. That will run about $80-$120 per device depending on configuration. This hardwired system doesn't use cat5 it uses a 14 gauge control wire.
Keep in mind a few things with hardwired solutions:
1) In the case of LiteJet, You have no load bearing devices in the individual rooms - cat5 connected keypads. You therefore have some duplication of devices - ie. - a load bearing device in your panel and also a keypad in the rooms. This adds a little to the cost.
2) When looking at the hardwired solutions, also make sure to feel the keypads that you will be using in the rooms. Opinions vary but some of the solutions I don't think have a good "feel" to them - some of them do.
