cheekymonkey
I have a problem in our house where there is confusion as to if the dishwasher has been run or not. I was thinking of using a ELK-M1ZTS and the long probe to monitor if hot water has been discharged down the waste pipe, if it has assume a cycle has been run and set an output.
The only problem I could see is mentioned in the manual
"The Control stores each temperature reading but discards rapidly changing readings as follows: If a reading is more than 20 degrees higher or 9 degrees lower than the last reading, it will be regarded as a possible error and discarded."
Does this mean it will only discard the first one or so or does it mean all measurements 9 deg higher than the last valid reading will be ignored.
Anyone have any experience using the M1TZ in this sort of way.
