Do you happen to know what model cameras? I do not want to spend a few hundred dollars but don't mind spending more money if I am going to get decent quality.Dan (electron) said:I have had a few Vitek cameras, including ones with the IR LEDs, and never had that halo ring effect. I have had a lot of trouble finding a good camera, even when willing to spend a few hundred dollars :/
How big are those cameras? I am looking for something as small as possible at a reasonable price. Would actually prefer something smaller than the Viteks I got, but their size is acceptable.Dan and others, these cameras are really good. We just installed 10 of the first camera on this page at work. The quality is very good. As good as I've seen in an IR camera.
http://www.supercircuits.com/Security-Came...curity-Cameras/
( PC332IR-HR )
I think a lot of your problems can be fixed by adjusting your brightness and contrast. Start by resetting both of them to 50% or their middle settings. Then adjust the brightness knob until the black level (that car would be great for this) shows some detail (I.e. not "pure" black) but dosn't look grey. Then adjust your contrast knob until the whites or brightest part of the image is a showing detail, but not "pure" white. The worst part of your Vitek screenshot is the contrast is way too high, after that it's a bit too sharp. The outside night image of the trees has its brightness way too high. Again, black should be black but not pure black, and definatly not grey.I have brightness, contrast, hue, and saturation controls. I played around with them the other day but was unable to get a better picture.About it being washed out -- the halo affect is probebly caused by the light ring... During the day -- do you have contrast & brightness controls you can adjust? The image also looks over-sharpened...
I will try swinging the camera around towards the back of the house tomorrow for a more balanced scene.The center of your screenshot is black, which causes auto-iris controls to brighten the image (washing out everything else)... What does it look like with a more ballanced scene?
That is because the OP had a typo. It is an IRLED24a, not a TRLED24a. Change that one character and you get a lot more hits. Hopefully the OP or a mod can edit the OP?Google Search
interesting that I can google the PN of this cam and I get only2 hits - one of which is this thread - the other is the manufacturers website....
It shows the lens as a varifoca (Lens Built-in vari-focal f=9~22mm / f=2.9~10mmA question to camera security gurus
The replacement outdoor dome I installed is an Everfocus Model EHD350/H-1. It faces SW.
Everfocus
Right off noticed that my field of view is smaller than previous dome. I need to adjust it a bit.
Noticed that I can adjust a few settings on it and would like some recommendations:
Here are the specs - will most likely unplug the heater.
Pickup Device 1/3†Sony Interline Transfer Super HAD CCD
Video Format NTSC or PAL
Picture Format 768 x 494 (NTSC) / 752 x 582 (PAL)
Horizontal Resolution 560 TVL
Video Output BNC 1.0 Vp-p, 75 ohm
Sensitivity 0.5 Lux/F=1.2
S/N Ratio Over 48dB (AGC Off)
Electronic Shutter 1/50 (1/60) ~ 1/100,000 sec.
Sync. Mode Line Lock/Internal Sync.
Flickerless On/Off switch
Backlight Comp. On/Off switch
Auto Gain Control On/Off switch
Auto White Balance Yes
Gamma Correction 0.45
Iris Level Adjustable
Dimensions (W x H x D) 130 x 98.8 x 130 mm / 5.1†x 3.9†x 5.1â€
Operating Temp. -40°C ~ 50°C / -40°F ~ 122°F
Humidity 20% ~ 80% humidity
Power Source 12VDC/24VAC
Power Consumption With Heater:
24VAC: 20.5W max. / 12VDC: 11.5W max.
Without Heater:
24VAC: 6W max. / 12VDC: 4W max.
Weight 1.7 kg / 3.7 lbs.
Weatherproof IP66 rated
Vandal Resistant Yes
Hope this helps,
Kent
