apostolakisl
Do those of you who use or install the whole-house water shut-valve also have whatever controller you use also shut down electrical power to the water heater? I'm thinking of a scenerio where we are out of the house for a few days and the water heater drain valve decides to leak. The Elk senses the leak and shuts off the water supply. As the water level drops below the heater elemenets, the elements overheat and burn out. It seems I'd want to install a relay box at the water heater feed to prevent that damage.
I have the on demand hot water tanks so with water off you have no flow and no flow means no burner on. Assuming you set the relay to shut the tank off every time the valve closes, then you will not be able to close that valve except under a leak condition. In my case, I shut the valve off 30 minutes after the alarm is set to away, protecting me regardless of where a leak occurs. That wouldn't work for you because your tank would get cold every time you left the house for more than a few hours. If you set your valve to only close in the event of a detected leak, that would prevent the cold water problem, but you would only protect yourself from leaks where you have sensors. No matter how hard you try, you can't put a sensor everywhere you might get a leak!
I guess you could switch to an on-demand heater. They are more efficient (especially compared to electric tanks), produce endless hot water, are very small, and almost never leak (as opposed to tanks which pretty much always spring a leak around 10 years). Of course, a retrofit job on tankless could be pricey if you don't have large gas lines and flu access.
