OK, then when you add Motion, add ZoneMinder (www.zoneminder.com), another fine choice for Linux.electron said:Not really, just wasn't thought of![]()
Jeff, using Microsoft Virtual Server will sap the CPU advantage out of running Motion on a lean, clean Linux machine.jeffx said:How is "Motion" on CPU usage? If it is more reasonable than Active Webcam on Windows XP, I might consider installing an instance of Linux on my HA PC (running along side Windows XP using Microsoft Virtual Server).
Also, got the 8 port 240FPS capture card (the blue one with the heat sinks) from another eBay seller and am loving it!
Here are some screen shots of the setup interface. Blue iris also lets you configure much of the motion detection. I really like that you can mask out portions of the camera image (like the street) that have motion that you do not want to capture by blacking out part of the image.electron said:I looked at the site, but I don't see any screenshots of the setup interface. Active Webcam allows you to configure many aspects of the motion detection algorithm, which is what makes it a winner for me, can you post more details?
You sure? You'll have to switch a lot of software... like your operating system software...and it would be great if a pop up window would open up when motion has been detected since the tv seems to be running all time anyways. I'll switch software in a second if this feature was available!
