Glad you found a solution. As someone pointed out to me on another board, a hall effect sensor output would need to be rectified as well.
http://www.appdigusers.com/forums/ubbthrea...3279/#Post19421
I'm still look at hall effect sensors for my "intelligent" power bar. Using a current transformer would be tough because I need to be able to measure from a fraction of an amp up to 10A+. I gather this is hard to do with a current transformer since you need to tune your resistor and wraps to the current to get the voltage you desire on your output.
Tim
Tim
