First.. Heya all!
Next...perhaps I'm still in the X10 Mindset here, but... X10 modules have the ability to work with local control--the control switch being the on/off switch on the device plugged in to them, e.g. the lamp, etc. So if I happen to turn off a lamp using X10, I can use the lamp switch to turn it on again.
my Zwave (intermatic) modules apparently don't work that way, OR, the one particular application I'm using one for is flawed. I have an undercabinet lighting setup, 2 x 18" each with about 6 very mini incandescent bulbs. Those units are plugged into what amounts to be an extension cord, that is on/off controlled by a touch pad (discreetly mounted under the cabinets..touch the bottom of the cabinet and voila' instant light. ) to top it off, it's a 3 way switch--1 tap = dim, 2 = medium, 3 = full bright and one more turns everything off.
So I plugged the Lamp module in to the "extension cord" and got it working as I wanted via Zwave. Cool. Then, when the unit was off, I hit the touch pad to turn on the lights and nothing, nada, zip.
So, my questions would be: Do the Zwave modules support local on/off OTHER than the switch on the module itself? (very inconvenient, the module is mounted way up above the built in microwave, with the extension cord coming up through the top of the cabinet, then down via some pathways in between cabinet carcasses) If they do support it, could the touchpad be the issue? (time for more testing) or perhaps the current draw is too low?
Thanks in advance, and I'm looking forward to learning more and more about Z-wave and applying the technology to the house!
-Craig.
-Craig.
