Wonky to say the least!  I agree, I don't think the normal serial port issues I have (on several different devices) where I need to delete and re-add the port are normal for Vista or Windows 7.  The only thing I know is that even the Onkyo driver I made caused me issues issues to where the port would stop working on the first reboot unless you toggled the transmission received flags.
You are correct, the ONLY user who has ever reported a problem close to mine is Chuck (who has the same Onkyo receiver). For the polling issue, no one else has ever had to reset a port periodically like me and I've also tried reading in the older forums for solutions. Note this problem was different in a big way: I actually had to reset the hardware to fix it! Also port spy never shows anything when I have the issue I normally have, but this time data was shown as being sent. I've never had a hardware failure like this, all of my problems have always been fixed by deleting and re-adding the port.
For this new issue, when I viewed port spy, nothing was being received, but data appeared to be resent several times (due to the drivers architecture is resends a job if there is no response), then after 3-4 tries the job was thrown out and the next job was processed, resent (no reponses), job thrown out etc... The port status showed open and data was shown in port spy as being sent.
Hopefully I can use an old laptop as a test machine and send 10 second polls for a week and never reset the serial port to see what happens.
