I am replacing my current panel with an Elk M1. Looking to connect with alarmrelay through the internet primarily with an ELK-M1XEP. I do have concern that the internet into my house is rather obvious (as was the old telco phone line) and easy to disconnect so I would like cellular backup. Been reading posts all morning and see the Uplink 4500EZ and the Telular TG-1express as primary options (or the TG-4).
Not sure which is better option, both in terms of easy of installation, cost, and reliability. I think there is a reasonable chance I will want the cellular in a different room than the panel (with cat 5 of similar connection). The Uplink requires other equipment, including power and battery for the unit and, I believe, the ELK M1-XSP. Not cheap. Can the TG-1 suit my purposes and require less addition equipment to connect.
Basic configuration on ELK is expected to be:
ELK-M1GSYS4
ELK-M1XEP
ELK-M1XRFEG
My sensors are existing GE sensors from my old 1996 Caretaker Plus system. I have checked model numbers and they should work with the ELK (at least most of them, the ones I looked at).
Any advice most appreciated. Sorry if I may have posted segments of this on other threads, but this is best way to get thoughts together.
ELK-M1GSYS4
ELK-M1XEP
ELK-M1XRFEG
