Guys,
The install *should* be pretty straight forward.
1.) Install board, Plug board into ethernet
2.) Connect included cable from the Notifier to the OP2 Serial Port. (Dont' use Serial Port #1)
3.) Using PCAccess 3, change serial port the "Email Board"
4.) Write Setup to Omni
5.) You should see Nodes for the Email Board appear in the treeview. Click on "E-Mail To Addresses" and add an address
6.) Click on email messages and add a custom message (for testing)
7.) Click on "Email Notification Board". Enter your SMTP Settings. (Google works well for testing).
8.) Click "Send Test Email". It will want to write to the omni and the email board.
9.) Watch the Email board LED. It will blink FAST when it is attempting to send an email
I'll try to help troubleshoot... but I'll need some information
1.) What controller Model and Firmware version are you using?
2.) What version of PCAccess 3?
3.) What serial port are you connected to?
4.) Did you change the serial port to email board and then dowload setup to the controller?
5.) The board is powered ONLY from the Omni Serial Port. The barrel connector is 5V, and is not intended to be used.
6.) Buttons are for internal / future use.
7.) With the board installed and powered, do you see the LED near the Buttons Blinking?
8.) There have been some reports of bad cables. We are investigating. If you check everything else, the LED is blinking and you see the LED's on the controller serial port blinking when you try to send a test message, You should check the cable.
Edit: All boards were tested and updated with the latest firmware before they shipped. No need to update the firmware.
The 5V connector is not intended to be used with an Omni. It's intended to be used incase you are connecting to a different panel or maybe for some standalone applications
