Just remember to use the wire that they provide with the CT while inside the breaker panel as I am sure that the wire is rated appropriately for that application.
I know I'm a pretty conservative person but the popularity of this and the TED unit has me very concerned, mainly with the do-it-yourself 'er opening the breaker box back panel. I type this with mixed feelings as I also don't want to be labeled as an
alarmist either.
Extreme caution must be taken when you expose live parts, especially when these parts are wired to a circuit/supply capable of over 100+ amps unfused. I have taken my panel off and was VERY nervous the entire time until I had it back in place.
What's worse with this situation is the proximity one has to install the current taps, right next to the input feed to the panel. I'm sure most people will not use an electrician for this part and install these components while the system is "live".
Just to give some normalization to this scenario, let me explain how this situation would be handled in our workplace.
1. First, in order to perform "live work" you need a line level manager's approval. This is usually three to four clicks above an immediate supervisory level.
2. You need
solid justification(s) that the work needs to be performed live. Not feeling like going through the motions to have power removed would not qualify.
3. You need to have isolated rated tools and insulating (approved for this type of work) gloves, plus a face shield and long sleeve cotton shirt.
4. You of course need to be trained/certified.
5. You must have an observer who is at least CPR certified.
6. You must have a detailed listing of the procedures, and those need to be approved by electrical safety professionals.
I'm not an electrical safety professional, but I have attended classes taught by national laboratory experts in this field.
After stating all of this, would I install the current taps myself without removing the main house power feed? Well, to be honest, probably yes, but I would:
Try to at least obtain the proper insulating gloves and wear (the larger type) safety glasses.
Have an observer nearby during this process.
Use caution when removing the panel. Make sure all mounting screws are removed and the panel will come off "straight" (i.e. without being tilted into the exposed feed studs at the top).
Make certain that the CT's are installed so they will not contact any exposed components. Also insure they will not "slip" down the cable over time towards exposed components.
Run any wiring away from exposed components (don't lay any wiring across a live piece of the main feed bus).
I would also welcome any of our residential electrical code expert's comments on running monitor type wiring from the breaker panel to an external low voltage device.
Again, I hope our members take this post with the spirit of which it is intended and that is for the DIY to know the cautions that this type of installation demands.
