drvnbysound
Thanks for the input guys. Exactly why I wanted to ask and find out first
In an ideal world, you'd only patch the ones to the splitter that are actually in use, and you'd use terminators on the unused ports on the splitter. Once you patch the other unused ones, theoretically you should terminate at the other end (usually the wall plate) but that'll still come at a cost to signal.
If something isn't electrically connected to the distribution system, it's not relevant in the termination sequence. Meaning, signal comes into the house, hits the distribution panel, then out to various receivers. At each leg of the cable should either be a receiver or a terminator. If you don't hook unused cables into the splitter, then they don't matter.Really, my question was is there any reason to use terminators on the unused cables that run from the various rooms (terminated into wall plates), to the patch plate? Basically these are just unused wires that aren't connected to anything at all...
Unused ports at the splitter or any run that is connected to RF signal needs to be terminated using appropriate terminators.
If they're not connected/patched, you don't need to terminate, but a lot of times, we'll terminate the wall plates and patch everything through and split at the head end even though the field equipment isn't there, just taking all the losses, etc. into consideration from the get go
Yes, OUT1.
I'd recommend ditching the 73 and just going with 4 SP12F's and knocking the total load to 8 ohms across the board. Better sound distribution also.
