5.7e - Conneting, please wait...
Jrock
I just installed my 5.7e and it just says "Connecting, please wait..." After it displayed that message for a while a disconnected and reconnected it to cycle power and I get the same message.
Any suggestions?
-Jeff
edit: This message came up after I pressed "OK" after doing the initial network setup. DHCP is off...
Any suggestions?
-Jeff
What do you consider "awhile"? It connects and downloads some information from the controller at first start, it should only take a MAX of 30 seconds or so...how long did you let it try to connect? If it is taking longer than say 1 minute, you probably have some network information incorrect. Press and hold on a "blank" spot on the screen for 5 seconds, and you'll be back in setup.
Aaron
Aaron,
Thanks again! You have been very helpful with getting my new Oiie setup. I did not set the controller communication properly on the 5.7e.
-Jeff
