drvnbysound said:Yes, both ends of an Android cable are 'some' type of USB connector. But that's exactly the problem... it's not a standard type. I think most all Androids are currently using micro USB, but without a common form factor and connector location 3rd party manufacturers have to invest a lot of money to design and produce a docking station or case for a single device... and how long is that device going to be relevant before the form factor changes?
BTW: Proprietary items are generally only made by the prime manufacturer... that's what makes it proprietary. The 30-pin and the new 8-pin connectors aren't proprietary - there are plenty of manufacturers that offer their own products that use both of these connectors... including Monoprice: http://www.monoprice.com/products/product.asp?c_id=112&cp_id=11213&cs_id=1120107&p_id=9928&seq=1&format=2
"One analyst speculated that Lightning could, just like the 30-pin connector, be used as the standard Apple charger and data connector for a decade."
The USB's are universal, off the shelf items. A standard end on one side and the only variable is the one at the phone, which is usually a micro USB. The earliest ones were mini USB (think BB's) and the droids became micros....very common and universal cords and devices, but as alluded, the form factor and location is the variable.
Without bashing or starting the flaming, those 30 pin units are used by other manufacturers, but the real issue is the pinout from the IOS to other manufacturers vary significantly...IE: Sandisk uses the 30 pin but the power is on a different pair than the IOS units.
IMHO, I could care less about a plug in dock for the phone as long as there was enough of a whip to reach anywhere I could have the USB on the hardware....which is what a bunch of the items I've integrated use.
