TurboSam said:@RAL: If I have an AL600ULX or an AL400ULX with a back-up battery in the same can, do you mean the outputs from the battery connect to the "input" side of the LPD and the the "out" from the LPD then goes to the "+ BAT -" connection on the circuit board in the AL600ULX (which is described in the installation instructions as "Battery Connection (non power-limited)"?
Or am I missing something?
The Inputs to the LPD connect to the power supply board, and the outputs of the LPD connect to the battery.
The LPD monitors the voltage coming into the input terminals. When the voltage drops below 10.5V, the relay drops out and the output is disconnected, and remains disconnected until the voltage on the input rises above 10.5V again.
So, at the time the AC power goes out, the relay is closed, and the battery voltage continues to hold the relay closed. Once the battery drops below 10.5V, the relay opens. It stays that way until the AC power comes back on and re-energizes the relay, and begins to charge the battery.
If you connect the LPD backwards, with the battery connected to the input side, it will work - just once. Initially, the fully charged battery will activate the relay and allow the power supply to keep it charged. When power goes out, the relay will still be closed, and the battery will power things until the voltage drops below 10.5V and the relay opens. Once that happens, when the AC power comes back on, the relay won't close, and the battery won't charge because the LPD is looking input side voltage, where the battery is still below 10.5V.
Here's a picture of the correct way to wire it.
