Sorry to bring back an old thread, but this is something I'm dealing with. I too planned on moving the components to a flush-mounted can, when I came across this thread. I guess I'm okay with mounting the P412 enclosure (with battery inside it) inside the bigger can, but did anyone actually do this? Was heat a problem? I've seen two measurements for the depth of the P412 enclosure on the Elk website (3.25" and 3.50"). Does anyone know for sure if it will fit inside an Elk 28" can? How is the P412 enclosure mounted in the 28" can? Did you mount it such that the J box knockout in the bottom of the 28" can could still be used, i.e., raised it up a few inches in the 28" can?
Ira
Well, it's been 2 years and I haven't updated my original set-up much. I ended up going for something similar to wuench's setup, i.e. leaving both batteries and the P412 electronics in the 14" can (see his pictures above). My 28" can is full, so that was a good decision...
That said, I managed to find my old P412 box and a spare 14" can. The P412 enclosure does fit in the 14" can, although not by much. The P412 cover fits right beneath the top and bottom"tabs", so that's maybe 2-3mm clearance from the door. The lock sticks out but I had no issue closing the 14" can door. So a close fit, but still probably a fit. I am not sure if the mounting is easy. You can always drill new holes in the back of the big can if needed. Note that the 14" can is pretty much filled by the P412, so keeping the P412 enclosure is not a great use of space.
Also note: the 14" can has a flush-mount accessory door, so you can reuse your original can with a new door (although you obviously can;t also put the M1G main board in it).
Laurent
