Checking UPB firmware versions...
hucker
Today we had a problem with a switch and I looked at it in upstart and found that it had the delay parameter! (I recently upgraded upstart so I would not have seen this before) I bought all of my stuff in May/June! How could that be? It turns out that I have 5 switches that are 2-40's with the 1.13 software in them. The programmable delay is enabled on these switches.
The easy way to check all of your 2-40's is to bring up upstart. Under View select List mode. One of the (many) columns is firmware. Click on the column header to sort by this field. If you have any 1.13 2-40's you can see them grouped together...
Pretty cool. The only problem is that these switches are not in the 'ideal' (relative to WAF) places so I'll have to do some switch juggling....
