After much research and thought, I've decided to purchase a Caddx NX-8e. I'm concerned with a couple of compatibility issues, as well as how to make the install at the panel fairly organized. The system will start with roughly 18 wired zones, 4 wireless zones, 2 keypads, and 2 fobs.
The primary non-sensor components are:
NX-8E + box
NX148E-RF (main keypad)
NX1448E (secondary keypad)
NX216 or NX216E -- does the NX-8E require the NX216E or is it compatible with the NX216?
2 x NX470 (keyfobs)
NXP003 (serial cable)
15-20W Interior Siren
30W Exterior Siren
Strobe
Just curious if I need the NX216E or if I can use the cheaper NX216, and want to confirm that the keyfobs will interface with the NX148E-RF properly.
Does the board or the serial cable come with the DL900 software?
I have not read about the NX-8E requiring a siren driver; does it need a special driver for 1 or 2 sirens?
Finally, when everything arrives...how does it mount in the can? Are mounts/standoffs included or separate? I'd rather spend the time to do this cleanly once, but no where do I see anything about standoffs/mounts/slides/rails/etc for this system. Tips/Tricks/Suggestions? How much space will be left in the standard NX-8E can after installing the two boards and a battery?
Thanks for the insights. The forums have already been extremely helpful.
NX-8E + box
2 x NX470 (keyfobs)
30W Exterior Siren
Strobe
