I just ordered a Sherwood 4109 to replace a Aiwa receiver that broke for the 3rd time. Right now I am using it with two sets of speakers and have it set up with a remote extender so I can control it from both locations.
But I want to set up computer control and go more to the whole house setup similar to jwilson56 and have a few questions...
How to keep the computer in sync with things that toggle with each button press. I see the power has a standby button so that should be easy. But the FM/AM button, speaker buttons and probably a few others toggle with each keypress.
Has anyone had trouble with two sets of 8 ohm speakers? The manual states they should be 16 ohms if both are used at the same time but 8 ohms is standard - Seems strange but I have read that most amps have similar requirements. If I don't crank up the volume is this going to be a problem? If so perhaps I should just get another receiver. Or should I look at matching transformers or something else?
Any other quirks I should be aware of?
I am planning on using LIRC under Linux. I haven't used it before so I may not be using the right terms but are the codes for this receiver available on the net or will I need to teach it each key myself? I plan to use some homebuilt hardware.
Thanks!
Thanks!
