custom GUI feasible ?
basilio
just out of curiosity,
how much would it cost if I provide all pages needed in HTML ? and could I upload it via http://..../webguiload ?
how about if I only need to replace the main "index.htm" page, and keep everything else the same would it be cheaper ?
I am running v03.02.17f, Thx
If you are using WebControl for your own product, you can write directly to us for discussion.
Normally, if you order large enough qty, we do not charge you anything, just take your gui change and generate a gui update image for you so that you can load it yourself.  If you just want to do few board, then we will charge time and material for the time involved.
The GUI change process is that user provide us the change they made to the original HTML file. Those original HTML file can be saved by right mouse click on the GUI page, then save as the same HTML file name in one directory.  If you are not familiar with HTML code, you will need to hire a HTML code developer to help you.  We only generate the gui update image file for you,
Yes, 3.02.17f firmware allows remotely update both firmware and GUI by owner of the board.
