I believe the DS10a only transmits changes and never transmits constantly.Sounds like you have a constant closure which is draining the battery.
But the heartbeat has nothing to do with weather the sensor switch is opened or closed, hence it is a constant battery drain, regardless of the state of the switch. right? Or it is a heartbeat only in one state?It does in fact transmist a heartbeat every 60 minutes or so.
What it could be is draining the battery by there being some sort of bulb in the switch.
I don't think a bulb in the doorbell switch would cause a problem since the unit is designed to work with a sensor that presents a dead short.
I think he just had a set of weak batteries. Is the issue repeatable when starting with known good batteries? Do you get longer life from other DS10As in your house?
