I have a DSC power series 1832 and system sensor smokes and CO detectors hooked up with a COSMOD. It all works great only problem is when i get out of programming i get a trouble for a couple of seconds. I only started when i hooked up the COSMOD. Anyone else had this problem?
When you go into programming it probably drops the power to the COSMOD module. when you leave programming the DSC is faster than the COSMOD to stabilize and hence the trouble. If it hangs in trouble, key in *259# to clear it.
