I just installed an Aladdin Light lift (like a garage door opener for a chandelier). It has a low voltage key switch to control the up and down movement. Turn the switch right it goes up, turn it left it goes down. Middle position is stopped. I have attached a picture of the key. I want this light lift to be controlled by a KP2 near the chandelier. I need one signal from keypad to raise and another signal to lower. I would like it to work such that the key must be continuously pressed for the movement to continue. Once the key is released the movement should stop. The other alternative is to have a third key be the stop key. Also would be nice to have these keys be protected by code so that kids wont be able to play with it. Can someone help me understand the right way to do this?
Robolo
Robolo
