I just started IP monitoring with Alarm Relay using M1XEP. The set up took only 5 min and everything looks good. However, they are saying that they are not seeing the "Alarm Abort" or "Alarm Cancel" signals from ELK. They are further saying that this is normal for ELK because they do get the final "Restore" signal which indicates that everything is fine. I am a little puzzled by this. Is this a known issue? If yes, is there a software update to fix this issue? (I have the latest 1.3.28 version of the software). I also have checked the Alarm Abort/Cancel in Area RCs under the communicator. Not sure what else I might be missing. Any help would be appreciated.
