apostolakisl
More on time servers - the Elk sometimes has issues with DNS which is why I used an IP address; also I would think it's better to have your time sync after 2:00AM when the time shifts that way it corrects sometime in the night.
That isn't how time servers work. The time server does not tell you what time it is where you are and it does not tell you the new time after switching on/off of DST. When you query a time server you get the same number regardless of where your machine is or whether it is on DST or not. It is up to the local machine to run a formula to turn that time server number into the local time.
The Elk is supposed to change the clock at 2am based on its internal clock. The time server is just there to "tweak" the clock when it drifts a few seconds off. Of course the time server info will also full out set the clock on a new install or full power cycle, but again, it is the local machine that decides what hour it is.
For example, I am using the exact same time server on my routers, my isy, and my server. None of them screwed up.
