I have a connection problem whit my ELKRP and M1 after suffer of power failure yesterday,when I try to connect the ELKRP a dialog show this:
"SYSTEM DID NOT RESPOND CANNOT DETECT BAUD RATE SETTING"
I try to change the serial port setting but dont see any problem,I'm using a serial port connection with M1 and newer have a problem,I check for cable broken but no found problem ,also my Homeseer-M1 plug-in work perfect and use the same cable(custom made 50' cat 5).
please I need some help here!
