Some of the recent Zigbee lock posts prompted me to go back and complete the setup of my Kwikset Zigbee lock to my HAI panel.
Until now, I was just using the lock in stand alone mode.
I've enrolled the lock with the ZIM and configured the lock as a Zigbee type under Access Control as Reader1 and can successfully open, close and read the state of the lock back - so far so good.
I have my user codes configured to allow control of Reader1 and if using Haiku I can change the state, enter a valid code and the lock state changes.
Is it possible to use the HAI user codes to unlock the unit from the keypad on the lock itself? The only codes that work from the lock keypad itself are the two initial ones I configured by pressing the program button and entering directly.
The lock documentation suggests that codes should be added and can only be removed from the System Controller (which I assume is the HAI panel/PC Access).
Beyond that, I can't seem to find any documentation at all.
Thanks in advance
Thanks in advance
