HAI Omni engineer/developer thread
JP10JP15Note
EPROMOPENOPENEnable lines always conneced to socket pins.
EEPROMSHORT RSHORTConnects enable line from EPROM to EEPROM
COPYSHORT LOPENConnects Program EEPROM enable pin to Language enable pin presumably to allow copying from EPROM to EEPROM (recovery).
JP10 connects the code EEPROM enable line to the Code EPROM enable line (Jumper Right) or the Language EEPROM enable line (Jumper Left)
JP15 connects the Language EEPROM enable line to the Language EPROM enable line. It is presumed this should not be shorted if JP10 is jumpered left.
TPValueLocation
TP1By expansion port
TP2Below expansion port
TP3By expansion port
TP4By expansion port
TP5By expansion port
TP6By expansion port
TP7Left of DSP
TP8
TP9Below right side of expansion port
TP10Below right side of expansion port
TP11
TP12+5.0 VDCAbove Program Memory
TP13+3.3 VDCTop Right
TP14~5.0 VACTop Right
TP15+1.8 VDCTop Right
TP16+12 VDCBottom Right of board
TP17-10 VDCTop Right
ConnectorNameDetails
J8Hardwired Expansion Bus
P1Chip Enable 1Marked "Address 1" - One of four chip enable lines.
P2Chip Enable 2Marked "Address 2" - One of four chip enable lines.
P3Chip Enable 3Marked "Address 3" - One of four chip enable lines.
P4Chip Enable 4Marked "Address 4" - One of four chip enable lines.
P5Data TX
P6Data RX
P7Clock
P8
P9
P10
P11
P12
P13
P14Ground
P15+12 VDC
P16+12 VDC
P17Ground
P18Ground
P19Ground
P20Ground
J92-Way Voice Module
P1Ground
P2
P3+12 VDC
P4Ground
P5
P6
P7
JPMProcessor Debug
P1BKGD/(TAGHI)
P2Ground
P3N/C
P4(Reset)
P5N/C
P6+5 VDC
JPDDSP Debug?
P1
P2
P3
P4Ground
P5
P6Ground
P7
P8Ground
P9
P10Ground
P11
P12Ground
P13
P14
Comparing 4.0b. EPROM contents show up on EEPROM starting at offset 0x00300000
Memory Map
AddressContents
0x0000 - 0x000F0xFF
0x0010 - 0x001F0xFF
0x0020 - 0x002F???
0x0030 - 0x003FEPROM Image
I updated post #8 with a new MODA pulldown location that more reliably lets a debugger reset the cpu into Special Single mode for dumping internal EEPROM.
Now I'm mainly working on the telephone circuits. If anyone has traced out the signal paths, on/off hook detect, ring detect, etc. please post a schematic or notes in this thread.
Thanks for updating that.
At this point in time, what are your specific goals in reverse engineering?
If I had the skill set, mine would be:
  • Ability to dump and upload eeprom within the MCU to change board type, reset codes, etc.
  • Reverse the main flash to enable updating code, adding and deleting features, etc.
  • Reverse console bus to enable making replacement consoles, new 3rd party integrations, etc, via RS485.
  • Get or reverse code base for android based OmniTouch7 touchscreens to allow 3rd party replacements.
  • Get or reverse code base for snaplink to extend lifecycle of this software for remote access.
I've been busy with other projects but did finally trace out the phone circuit on my OmniPro II (schematic attached). There's not much in the audio path to go wrong. Besides a bad capacitor or leaky transistor/protection-device, the only thing is audio codec U3.
I made a cheap alarm central station receiver emulator that lets me test the HAI panel phone circuit on my lab bench. When the panel dials out, the emulator sends a handshake, the panel sends its contact ID report and gets an acknowledge handshake (kissoff). I can see every digit it sent on my Windows laptop and measure signal levels/distortion with my instruments.
I based mine off this really cool project that does it with an old MagicJack + RaspberryPI running Linux, but that is way more complicated with notification reports and alarm control over ethernet. Mine is just a MagicJack A921 connected to a Windows laptop.
WARNING: Although his project describes using an original silver MagicJack, there were several production runs where all the later ones used a different chip that doesn't work with his code. All of the A921 silver MagicJack listed on Ebay use the newer chip (Tiger580) while his had the Tiger560B. Once I figured out which chip it used (nearly impossible) I was able to find a datasheet and get it working with much simpler code (1 file, 200 lines).
One thing I learned from this is the TEST CODE for AUTOMATIC TEST TIME doesn't do anything at least for Contact ID. I captured test calls with TEST CODE set to default 98 and also set to 53 and the same Contact ID string was sent for both: 5554181602000008
The DSP is the last subsystem to document. It handles voice messages, dial and DTMF tone generation/decoding, ContactID reporting, etc.
The TMS320VC5402 dsp chip is not connected to any external memory but has an internal RAM and ROM. It's extremely unlikely that HAI ever used enough chips to qualify for custom mask-programmed ROM so I believe the ROM only has the default bootloader and lookup tables. Communication with the CPU is over an 8 bit Host Port Interface (extended HPI8).
The dsp pins are configured to boot using the bootloader to load program code over HPI8 into internal RAM (MP/MC_ pin tied to ground, HINT_ tied to INT2_ ). I did a bus capture at startup and recorded the cpu reading the dsp program code from the firmware memory (addresses B0010-B2B7F in 4.0b OP2) and writing it to the dsp. Same for any voice message or tone data.
The cpu accesses the dsp using chip select CS0 memory space at addresses 0200-02FF. All dsp read/writes are 16 bits over an 8 bit bus so there are always 2 transfers. Only 4 addresses are used:
cpu addressdsp register
0200HPIC (control)
0202HPID (data read/write with HPIA autoincrement)
0204HPIA (internal memory address for data read/write)
0206HPID (data read/write with no change to HPIA)
This table shows the pins used by the HPI8 bus to communicate with the CPU (U59 is an extra data bus buffer only on newer rev boards):
DSP pinbuffer / translatorCPU pin
HD7 (6)<-> U23.3, .21 <-> U59.10, .14DATA15/PC7 (35)
HD6 (135)<-> U23.4, .20 <-> U59.DATA14/PC6 (34)
HD5 (124)<-> U23.6, .18 <-> U59.DATA13/PC5 (33)
HD4 (120)<-> U23.8, .16 <-> U59.DATA12/PC4 (32)
HD3 (95)<-> U23.10, .14 <-> U59.DATA11/PC3 (31)
HD2 (81)<-> U23.9, .15 <-> U59.DATA10/PC2 (30)
HD1 (69)<-> U23.7, .17 <-> U59.4, .20DATA9/PC1 (29)
HD0 (58)<-> U23.5, .19 <-> U59.3, .21DATA8/PC0 (28)
HCNTL1 (46)<- U24.16, .4ADDR2/PB2 (54)
HCNTL0 (39)<- U24.17, .3ADDR1/PB1 (53)
HBIL (62)<- U24.18, .2ADDR0/PB0 (52)
HR/W_ (18)<- U24.13, .7R/W_ (38)
HCS_ (17)<- U24.15, .5PF0/CS0_ (68)
HDS1_ (127)<- U24.12, .8ECLK/PE4 (48)
The DSP is the last subsystem to document. It handles voice messages and DTMF tone generation/detection, ContactID reporting, etc.
The TMS320VC5402 dsp chip is not connected to any external memory but has an internal RAM and ROM. It's extremely unlikely that HAI ever used enough chips to qualify for custom mask-programmed ROM so I believe the ROM only has the default bootloader and lookup tables. Communication with the CPU is over an 8 bit Host Port Interface (HPI).
The dsp pins are configured to boot using the bootloader to load program code over HPI into internal RAM (MP/MC_ pin tied to ground, HINT_ tied to INT2_ ). That means the cpu reads the dsp code from somewhere in the 2 EPROM (or NOR flash) chips and sends it to the dsp. Same for any message or tone data.
It's amazing work, and I would like to contribute if I can. Again, what is your goal with all of this reverse engineering? Build a modern board? Just document stuff for repair?
My goal is to enable the same level of repair support (by others with an LLC) that HAI/Leviton used to offer. Right now I can unlock a panel or replace any part including the cpu which requires EEPROM programming.
I'll stay away from modifying firmware since this is a life-safety device. Decoding protocols for automation devices is okay but I'll stay away from related life-safety things like wireless receivers, etc. However if anyone else works on those things feel free to post it here.
This thread needs at least one firmware disassembly listing.
The attached file shows the firmware code (4.0b chip) that writes 1 byte into the cpu internal EEPROM and gives an idea of what's involved in writing that EEPROM. I couldn't find a separate hw bulk erase subroutine so they must call this routine 4096 times to implement RESET SYSTEM EEPROM. Different firmware versions have the same code at different addresses.
A subtle detail of expanded addressing mode is important here: the final 16k page of program memory always maps to absolute address C000-FFFF. Even though this subroutine starts at EPROM location FC60F, it can always be accessed from C60F no matter what the program page register contains. This should mean that the final 16k of every firmware version contains the chip initialization code, interrupt vectors, and utility routines like this one.
This disassembly listing shows the initialization code with the setup values for all control registers, i/o ports and peripherals. This is key to any deeper analysis of the firmware. As mentioned above, the listing shows the code starting at address C000 while the actual EPROM location is FC000. It sets up the following memory map:
22-bit Expansion AddressInternal 16-bit Address
0000
01FF
CPU registers
0200
02FF
CS0 - DSP
0300
037F
CS1 - ?
0380
03FF
CS2 - peripherals: serial J2-J5, ethernet, etc.
3C0000
3FFFFF
0400
07FF
CS3+EPAGE - external EEPROM
0800
0BFF
CPU SRAM
1000
1FFF
CPU EEPROM
2000
6FFF
non-paged external SRAM
300000
3FFFFF
7000
7FFF
CSD+DPAGE - external SRAM
000000 (CSP1)
1FFFFF
200000 (CSP0)
3FFFFF
8000
BFFF
CSP1+PPAGE language EPROM
CSP0+PPAGE firmware EPROM
3FC000
3FFFFF
C000
FFFF
non-paged CSP0 EPROM
I am impressed with all the reverse engineering efforts here. Thanks the information provided is priceless considering Leviton did not release all of it after discarding the line.
