So I moved the CIM into the house (from the detached where I attempted before) and now I'm able to see all switches, but load into UPStart only on one phase. Network discovery shows about 55% of the switches with "Comm good" and "Loaded" and the other half "Comm bad" and "Problem."
When I do a Signal to noise check, the signal is full green, with spikes between None and Severe for one sample every 1-3 seconds. From the PIM on the OPII I get about a 95% success rate on switches on both phases, other than the ongoing programming problem with those two switches I mentioned earlier.
I'm not sure what the means or how to begin debugging. Do I jump into turning off breakers or does this mean anything that would cause me to go in a different direction.
