Tony:
I'm having some weird things happening with my switches:
- different switches seem to have different dimming speeds/rates out of the box...some are very fast where its nearly impossibly to set the lighting level the way you want it...others are a nice slow ramp the way it should be i think..
- 1 switch is controllable through the LV wires, but has no control via the rocker except when you press hard...then the light goes momentarilly off untill you release and it comes back on. Control via the red/black/green LV wires is as one woudl expect.
- 1 switch has normal control through LV wires, but will only turn off via the local rocket and not on. This really confuses me.. although i can't seem to trigger it i observed the light dimming (fading to off) by itself without touching the buttons and i checked and the LV wires were not touching each other or ground either...very strange..
Both of these were new in box. About 7 others from the same lot are generally working ok except for the different ramp rates..
Any suggestions? I know you said it's very rare that the switches are defective...but i've checked the wiring...the LV wires are local (not connected to cat5 yet) and the HV wiring is correct as far as i can tell...this is also confirmed by the light coming on and working properly when the dimmer is controlled through the LV wires..
Allow me the luxury of handling your questions after I explain my approach to tech support and hope that it does not annoy you. On the telephone I can smooth out my approach and avoid raising the blood pressure of the caller by not making them feel like I am accusing or doubting their word. Here, this is not as easy, so forive me in advance if I speak firmly!
Not actually being on site, it is difficult to do telephone tech support and harder to do email tech support because there are factors I can't see.
To do tech support it is necessary to understand a few "foundational things". Without that we may be on different levels and wasting time.
Here is a few core or foundational building blocks that must be established.
1. THERE ARE NEVER "TWO" BAD OUT OF THE BOX DEVICES. - PERIOD! In the case of ALC switches this is especially true. A few weeks back I mentioned my personal install history of ALC over the last few months. It is now approaching 500 total devices without a single failure of any kind (mechanical or electrical). OnQ claims a <2% failure rate, but also knows that of the less than 2% returned, most were damaged by the installer (and were still covered under warranty anyway).
2. IF IT DOES NOT WORK INTIALLY - CHECK YOUR WIRING!
3. IF IT FAILS AFTER SOME RUN TIME - CHECK YOUR POWER SUPPLY (or see number 2 for intermittent connections).
With that in place let's move forward on your specifics.
Unless you are using Scenetech software or the SDK (Software Developers kit), then the dimming rate is not adjustable and is fixed at the factory. The only things I can say is that your loads are a suspect. Unless you are dimming a load with capacitance or with some sort of electronics, then the dimming rate should be as set at the factory. Of course dimming flourescant loads is always an issue with any dimmer or any brand.
I confirmed this with Ramir at OnQ and he is also looking at this thread. I hope he can contribute more. However we both agree that the dimming rate is not a known issue (unless a funky load is a factor).
I have seen some flaky operation of the LV related to wires pinched against the switch chassis or other LV wire. Check your connections and the integrity of your cat5 run.
As for the rocker issues, this is also rare. You can disassemble the rocker (being careful not to lose the tiny springs) and reposition it. It sound like they are in a bind.
It is rare to have one problem related to the switch. So two is not likely. I stand on this so firmly that I INSIST that no person has ever got two bad switches out of the box.
Please send your load types and also recheck connections.
Hope this helps
God Bless
TS
