hult
The way we worked with the code is that the CAT5 is there to control a device (the i-line switch). That way, it was allowed in the box with the HV wiring. We had to show that the insulation rating was at least 300V and we went to the manufacturer of the CAT5 wire to get the answer for the inspector.I installed an EDT i-line system in my new house by myself 2 years ago. The switches are very responsive and I have had no problems at all. I am controlling every load in the house (64) with the switches. The i-line software is a little hard to grasp initially, but if you are controlling with an ELK, there is no need to use the i-line software.
They do not have lamp modules, so for planning purposes, if you want a lamp controlled by the system, make sure you have the lamp outlet controlled via a switch.
Pete
What is your (NEC) code-compliant solution for a _dimmed_ lamp using EDT i-line?
... Marc
I didn't use enough words to phrase my question clearly. By "lamp outlet", I assume that you mean a duplex outlet in which at least one of the outlets is controlled by the EDT i-line device. If this device is an on-off switch, that does not in itself present a code issue.
If the device is a dimmer, and it supplies 'dimmed' power to a standard Edison AC power outlet (eg NEMA 5-15) , it is my understanding that it would be a violation of the NEC 110-3(B)+ 404.14(E) (maybe others) and is certainly bad practice IMO. ( Watch that vacuum cleaner smoke ...)
Lutron makes an specialized connector set (eg NTR-15-HFDU outlet and RP-FDU-10 plug ) that has UL listing for dimming, but ABIK it is only UL- listed for use with Lutron dimmers -- of course ;-) www.lutron.com/pdfspecs/novatb.pdf
Because floor and table lamps are often used for 'mood lighting', being able to dim them can be important. With PLC and RF devices, the dimmer can be a wall-wart type so X-10, INSTEON, Zwave etc can be readily used to dim free-standing lamps in a code-compliant way. One could also embed inline ( not i-line ) dimmers using these protocols inside the lamps themselves to avoid unsightly wall acne.
With hardwired lighting, it is more of a 'challenge'. And I wondered if you or anyone else had a code-compliant solution.
TIA ... Marc
