Am I screwed??
I ran a single cat5 to several switches, everywhere. And then I homeran everything. I didn't run any wires from switch to switch for auxillaries, as I figured I could do that down in the basement.
Because auxillary switches are also punched down in the branch hub, I thought that the aux was affecting the switch via controller commands. In other words, that I WOULDN'T have to connect the aux wires from the master switch, just the + and - wires.
Now looking at the diagrams again, am I seeing it correctly that being connected on the branch hub does nothing more special than just make the same physical connection as if the aux was wired directly to the switch?
So in other words, each aux-controlled switch requires a full 5 of the 8 cat5 wires. So a single cat5 cable will not be able to serve 2 switches that also have aux controllers (3 or 4-way).
if so...then I am totally screwed. Or at the very least, GREATLY screwed.
