wdeertz
I've read through past posts and think I understand how the HLC mode works with UPB links and OP2 but would like to verify with forum experts how the syncing works.  I have my system setup with all rooms configured as HLC mode and the standard 6 allocated UPB links of on/off/80%/60%/40%/20% for each unit.  For rooms 21 and up I have these rooms defined as UPB to allow me to use these UBP links (other than the standard pre allocated) for other lighting scenes.
So my questions are:
1) when one of the standard allocated UPB links is executed (could be from PC Access programming, switch button, etc) does the OP2 automatically poll the status of all units in that room? Does this work both for when the UPB link is activated and deactivated?
2) I have a few lighting scenes which contain units across multiple rooms (let's say rooms 1, 2 and 3). So if I use one of the standard allocated UPB links for room 1 across these 3 rooms, would OP2 automatically poll all units in room 1 and to keep OP2 unit status proper I would program PC Access to poll status of all units in rooms 2 and 3? In PC Access would I need to have both a trigger for the UPB Link On and Off?
3) To get instant all on lights and all off lights I've created two separate UPB links for all units in the house. In PC Access I have programmed to update status of all units when either the all on or all off is executed. It's takes about 3-5 seconds per unit to poll status so it takes a while to get an accurate status for my 35+ units. Is there any way to speed up the status polling process or another approach to use to keep all units status accurate in OP2? As a catch all I have OP2 poll the current status of all units every 3 hours, given the OP2 limited CPU power does this put an unnecessary burden on the system.
