I run a production facility that has an overhead audio system. I want to use the night ringer from the audio system, for an alarm to send my employees to break. I have the WC set up and a vb app running that triggers the outputs at a specific time. It is powered by a 9V power supply. The audio system night ringer is triggered by a contact closure. My plan was to use the one of the 5v relay board as the contact closure and the WC outputs to pull in the relays. Can I power the relay board from the WC Humidity Sensor? I will be having a max of 2 outputs going high for a 5 second duration. Is there another way for the WC to act as a contact closure without using a relay board?
thanks,
Scott
thanks,
Scott
