Steve said:
You can not simply measure the voltage across the hot wires. It needs to be measured to neutral or ground. So yo neet to set your meter to AC voltage and put 1 lead on the neutral (which should always be white) and hot (primary should always be black). For 3 way there is usually a red traveller wire that goes between the switches. 3 ways can be configures in lots of different ways. Most of the time a regular switch works by just switching the hot leg, so you will have the hot (black) wire split with the switch wired in-line. An outlet needs to provide juice, so 1 side is hot and the other side is neutral. If you measure across those wires you should read 120. Normally the hot side is black wire and the neutral white. Sometimes electricians do funky things like use white whire as hot, but they are supposed to mark it with black tape or something to indicate hot. Normal wire color coding is something like:
Black = Hot
White = Neutral
Green = Ground
Bare = Ground
Red = alternate hot / traveller, etc
So for the 3 way, you really need to find which switch has the load wire, where the power comes in, etc. Most of the time you get lucky and 1 switch has the power feed and load and the second switch is mere a slave, but anything is possible.
well, i just pulled the plate off the other switch, had a little luck. I have a green, white, and 2 black wires. I measured voltage across each black and the green, only one is hot. I'm guessing that means the non-hot one is a traveller.
HOwever, looking at the ACT wiring diagram, they want me to run:
Q1)
- Green->Ground (got that)
- Yellow->Slave (traveller, right?)
- Blue->Load (this is hot, right?)
- Black->Line (huh?)
- White->Neutral (got that, but they show blue&white both going to load. )
Q2) In addition to those questions, I have 4 wires on my switch and they show 5 colors. What do I run their black to?
Also, depressingly the other switch is the one with the 3 black wires.
Q3) Do I need to replace this if it's a "never-ever-used" switch? We have our dresser blocking it.
Q4) I used a multimeter to test connectivity across both switces. Both my non-hot black wire and my white neutral read 0 ohms when tested against 2 of my slave black's.
I can take pics if that'd make it any clearer. Thanks for any help.
