Tony and Family,
Best of luck to you.
I have about a dozen ALC switches installed and another half dozen NIB.
My main beef with ALC which has had me questioning my choice is similar to others:
- Scene switches are terrible. Maybe they were ok 10 years ago, but they cannot compete with other suppliers look and feel at the moment.
- Outlet module. I understand a plugin lamp module can be a bit tricky since you need to bring the HV and LC from wall to the module. But an outlet module which you could have a lamp plugged in would be great. I understand there is some code issues with dimming outlets perhaps, for me a relay based outlet module would already be a big improvement.
Other pet peeves (which may or may not be solvable due to code issues and such):
- Having to put all the LV wires together and stuff them in the gangbox. Anyway to make it a RJ45 connector 'on top' of the switches so you can still run the cat5 outside the box pretty much. Maybe this is physically not practical.. but a plugin LV wiring would be grand and significantly cut down on errors i would think. One issue to keep in mind is that the polling loop wires may be used by multiple switches.
- Alternatively to the RJ45 solution can we get terminals on the switches for the LV? This way you could put a insulated sheath over the Cat5 and then terminate it on thw switch. If you put this under a plastic cover (which already seems to be there) maybe this can be made code compliant and still be compatible with your preferred method of keeping the LV on top and out of the gangbox.
- Documentation. Like others have said. It's a pain to figure out which pieces you need and how it all works together. Perhaps this is coz it isnt really a DYI product. I have to admit maybe it's a issue that us DYI HA geeks have where we plan everything out. Once i got my hands on the gear it all became a LOT clearer. Mainly for new construction home people to figure out how many conductors are needed seems to be tricky. Now that i've done it for my own home it's easy to explain to others. But some descent graphics (from this decade :horse: ) would be usefull.
- The way to have to teach scenes in the scene switches is really akward, especially if you're adding switches to your install and have to redo all your scenes. In reality I believe the scenetech software (which i havent used myself) fixes this issue. I somewhat feel this software should be available freely.
- I have some issues with the ALC<>ELK interface which i've posted about before but have gotten no real response from ELK.
- Delay between commands. If you turn it off commands are missed. If you turn it on the delay is signficant (about 1s) and annoying.
- ELK RP doesnt let you set the dimmer level to 0, you have to turn the dimmer OFF. This transition from level xx% to 0%% is smooth, the transition to OFF is crude. The odd this is that when you use CQC to set the dimmer level for the ELK which then controls the ALC interface you can set it to 0%, so this mainly seems to be an ELK RP GUI issue. Should be easy to resolve.
Although this all sounds a bit negative i've had ALC in my home for 1 year now. Due to time restrictions i havent made too many fancy scenes and such, but so far the system hasnt missed a beat. Depending on the price and developement of new modules I may stay with ALC (also because i've already sunk a good bit of $$$ into it).
Maybe we as DYI'er think ourselves too important of a market, but i don't think you'll find a bunch of guys more willing to take a chance on a product, test beta software, give you feedback on documentation, etc.
Classy and good political move on the price protection.
Best of luck to you and your family.
Felix
