wuench
One of my biggest issues right now is with my router. I can only connect with WiFi or 3G, not both. Because both show up as different addresses depending on how you access it and probably due to asynchronous routing. I have to disable WiFi to use EK+ in my house. There might be a routing solution, but I haven't found it yet. But it would be nice if the app allowed you to use multiple configurations automatically. So if it can't connect on one, it would try the next.
Not sure how this works for me, but it does. I point eK at my external dynamic DNS name and it works internally as well as externally. I believe it is because my router (Actiontec) NATs the packets even though they are sourced from the inside interface.
It depends on how picky your router is I think. I am running OpenWRT (linux) firmware on my Linksys and it doesn't allow NAT'd traffic to be routed from the inside without some complicated IPTables/NAT setup. I did end up fixing it. What I did was add a host entry for my external DNS name and pointing it to my Elk address. It's kludgy, but it works. So when I am inside, on wifi, the IPhone talks directly to the Elk bypassing the router. When external it uses the external IP and goes through the router....
