Lost My M1XEP during Firmware Upgrade
Mike P
Hi all,
I need a little advice, I did a bootware and firmware upgrade on my M1. After doing the upgrade I re-enrolled all boards with a direct connect to the panel. All is working fine except I can not access the panel via my M1XEP board. When I try, It connects and I then get a message "System Did Not Respond" After that I get another message "System Returned Invalid Information".
Any sugestions, I upgraded to the most current versions of boot and firmware. Do I also need to upgrade the firmware in the M1XEP? Any help would be great.
Mike
Here is a detailed response from the ELKRP Guru:
The latest firmware version for the M1XEP is 1.2.12. It wouldn’t hurt to upgrade to it. If the problem still persists, do the following:
1) Open the account in ElkRP
2) Click on Account Details
3) Press Ctrl-F5 to open a diagnostic window (You may have to resize it to see it better)
4) Connect to the M1 via network.
5) If you see a receive line that looks like this: RCV: 08RP0200 . . .
a. Check the cable connecting the XEP to the M1 – make sure it is snug and works.
b. Reboot the XEP (power cycle it) and wait 2 minutes for it to reboot. Try it now.
c. Use Keypad programming to check Globals G34 – make sure it is 115200 baud. If not,
i. Set it to 115200 baud.
d. If it is, change it to some other value, save it, then change it back to 115200.
e. Try that. If still no joy, default Globals Programming using G45 (refer to the manual).
f. Default the entire control.
6) If you see: RCV: 08RP0100 . . .
a. Make sure another copy of ElkRP is not connected to the control already.
b. Reboot the XEP.
7) If you see neither of the above,
a. Reboot the XEP.
b. Reboot the control and XEP together.
c. Try the additional steps below.
d. Contact your distributor for technical support.
Additional steps:
Hopefully, you’ve enabled the non-secure port (2101) on the XEP. If not, this won’t work…
1) Open HyperTerminal (HT) and create a TCP/IP (Winsock) connection to the XEP’s IP address, port 2101.
2) Press a few keys on the M1KP or trip a zone to see ASCII data in HT’s window.
3) If all you see is 08RP0200 . . . then try the steps under #5 above.
4) If you see valid ASCII data resulting from the key presses and zone changes, the XEP is working fine.
5) If problems persist, isolate them to the XEP/cable/M1 by doing the following –
6) Disconnect the serial cable from the XEP and plug it into a serial port on your PC. (note: if you use a USB<->RS232 converter, first make sure it works)
7) Use HT to make a serial connection using the COM port the cable is attached to, 115200 baud, 8 data, 1 stop, no parity, no handshaking.
8) If you see valid ASCII data, the M1 and cable are OK – problem may be in the XEP.
9) If you see no data or corrupt data, check the baud rate in the M1 (G34) and the PC. If still no joy, try another known good cable. If still no joy,the M1’s RS232 driver may be damaged.
Spanky, Thanks for your help. Everything is running fine. The M1XEP just needed a 2 Minute reboot. I did reboot it several times prior, But only for about 30-45 Sec. I powered it down for 2 Min. Started it up again and BAM....All back on line.
Spanky, Thanks again
Mike
