briankelly63
I am using the M1XEP's built in web application - virtual keyboard. I cannot DIM Leviton HCM06-1DW's (PLC) using the slider in the web application. The switches are configured as extended / dimmer in the M1G. Interestingly, Dim commands to these switches using rules work just fine but when using the virtual keyboard application they do not. Is this a bug or a limitation of the free, built in virtual keyboard application? Seems like a bug... I have some older Switchlincs on the same installation and the slider for dimming works fine on them... PLC commands are being sent as a result of moving the slider but apparently not the correct extended control commands.
Thoughts?
brian
Thoughts?
brian
