miamicanes
While reading through my new M1GSYS4's installation guide, I got the impression that each keypad (well, the original, and 'KP2 at least) can ALSO serve as a mini input/output expander, and host an additional input and output... above and beyond the 16 that can be connected directly to the M1G's control panel.
Is that correct? Does that imply that an out-of-the-box M1G with a classic keypad and an additional low-profile keypad can actually handle 18 input zones (with zones 17 and 18 wired to their nearest keypads instead of to the controller)?
On a related note... I've come to the conclusion that trying to bore a ~1" hole through the suspended slab between my first and second floor is pretty much hopeless as a DIY project (So far I've broken two 1/4" masonry bits just trying to bore the first pilot hole, and only have a little more than an inch of depth and a torn-off basebord to show for it). So... I started looking for alternate ways to connect the master bedroom's keypad to the M1G almost directly below. For some reason, the M1G's keypads apparently won't work with anything that tries to act like a transparent RS-485 bridge via some alternate transport medium (wireless, ethernet, etc), and I'd REALLY prefer to avoid doing something as barbaric as running the wires up the side of the house on the outside, which leaves... the original 6-wire phone line put in by the builder.
As far as I can tell, there's a straight, uninterrupted run between the telco demarc (which just so happens to be next to the M1G controller, and will probably never be used by an actual telephone again) and the jack in the master bedroom. So... I came up with the following idea:
* Use wires 1-4 for the keypad bus to connect the keypad in the master bedroom to the M1G's controller (which, non-coincidentally, happens to be right next to the telco demarc that will probably never again be connected to actual AT&T landlines).
* Connect wire #5 to the Zone 16 input on the M1G, and connect the other end (and the common neg wire from the keypad bus) to a 2-wire smoke alarm
* Connect wire #6 to the Zone 15 input on the M1G, and connect the other end (and common neg wire from keypad bus) to a pressure pad hidden below the carpet in the upstairs hallway between the master bedroom, computer room, and stairway landing.
* Connect the magnetic sensor on the master bedroom's window directly to the extra input on the master bedroom's keypad.
Does this sound like something with a reasonable chance of working?
