Guys, I could really do with some advice.
Yesterday, as I was typing an email my PC started to behave strangely and this has been happening ever since.
4 Obvious Problems:
1. When I type, a space is not always inserted when I press the space bar even if I go back and try again, then for no apparent reason it will "auto-type" space indefinitely :blink: .
This happens in all apps, not just outlook, which is when I first experienced the problem. This even "auto-types" spaces when I try to login to email services or pretty much whenever it feels like it.
2. When I boot up the PC, there is a very loud beeping that goes on for a fairly long time between the initial computer boot (when it says VAIO in my case) and when XP starts loading (this is when XP DOES load, as it often just stays as a blank screen).
3. When there are options and one is highlighted (eg. "Yes", "Yes to all", "Cancel" tabs), only the highlighted (default) one can be selected. This is quite infuriating.
4. The "powerbar" or shortcut bar, at the bottom right of the screen in XP, when maximized starts doing a max/min dance and can only be stopped by pressing one of the options, it will then be minimised. So I can never see it maximized at the moment (or at least not for more than a split-second).
I have checked the drive for errors, none found.
I have run Kaspersky AV and Norton AV, no viruses found.
I'm currently backing up my stuff and will attempt a clean reinstall of XP, but here again I have a problem: my optical drive is not recognizing any discs, and I don't have a floppy slot.
Is it possible to re-install XP from an external HDD using USB?
I have copied all recovery discs to my external HDD (thank God my girlfriend has a laptop), but I have no idea how I'll be able to browse to the appropriate part at startup.
Has anyone seen or heard of a problem like this before?
I am writing this post through my girlfriend's PC as it is pretty much impossible to write anything with mine.
Any suggestions or comments would be extremely appreciated as this is driving me crazy
4 Obvious Problems:
