Welcome to the Cocoontech forum larynx.
is it possible to extend the CAT5 cables using 2 PoE injectors?
No.
Not sure on the POE power drop after 100meters. An injector will not extend the 100 meter limitation of Ethernet.
You could maybe install a combo midspan injector / switch (X2) or use a POE and network media converter to fiber.
Googled and found a long range combo here:
Longspan
LONGSPAN delivers unprecedented power and bandwidth over extreme lengths of regular Cat 5e or Cat 6 network cable, enabling a dependable connection to IP cameras and other remote network devices.
As a point-to-point solution with no mid-cable equipment and smart, automatic self-configuration, installation is simple and instantaneous. LONGSPAN even supports single-pair UTP cables, providing a fast upgrade solution for legacy analogue systems.
With an unrestricted 100Base-T full duplex connection available at a phenomenal 800 metres range, and POE-equipped models delivering full-power 802.3at POE Plus at 600 metres, LONGSPAN assures reliability in the most challenging scenarios.
LONGSPAN is available in POE and data-only models.
or have a look at the Ubiquiti forum for a long range wireless CCTV solution.
