TeleFragger
WOW... hopefully in 2 weeks I will be able to order.... the c kit with 9 micro.... this is lookin nice!!!!!!!!!!!!!!!!!!
If it is desirable to have access to the kW and amps on each leg of the main service individually as well as the total, can we connect one CT to channel 1 and the other one to channel 2 and set the channel's CT option to single? Are there any special configuration settings involved for this arrangement. Any other issues to be aware of besides the loss of a channel that could have been used for omething else?
Thanks!
Brian
Brian,
That's the way we did it since our ECM-200 in 1992. Only lately have we started combining the two lines on one channel to open up a second channel. You would connect the CT to the COM and SINGLE terminals and set the CT settings to 167/4 for SPLIT-200 or 167/5 for SPLIT-100s.
Paul
I just purchased the Brultech serial to ethernet adapter. It came with no instructions whatsoever. Does anyone have the instructions on how to hook it up to the ECM-1240?
Regards,
Ultrajones
Regards,
Ultrajones
Kelvin's right - even though there's no mention of the EtherPort being zigbee related you use the zigbee config utility to set it up. I sent a tech support email to find out - Paul responded with the goods even though it was a Sunday.I just purchased the Brultech serial to ethernet adapter. It came with no instructions whatsoever. Does anyone have the instructions on how to hook it up to the ECM-1240?
Regards,
Ultrajones
Are you referring to the EtherBee? If so, download Brultech's EtherBee Configurator from here:
http://www.brultech.com/ecmsupportupdate.html
Click, "Search." Then, in the Server IP settings, set the ip address of the server that will read data from the ECM-1240. Don't forget to click, "Save Settings." The EtherBee will start reading data from the ECM-1240 and push it to that ip address and port. You can then hook up a server to read data. Brultech lists some server software at the above site. I'm also working w/ Brian on some python code, here:
http://bitbucket.org/kelvin/pyecm/overview
-Kelvin
tenEcmServer Receives data from ECM and broadcasts it to the other programs
tenHsEcm12xx HomeSeer plugin that creates devices that track ECM data, computes monthly cost, and charts real-time ECM data
tenEcmDbLogger Writes hourly ECM data to an SQL database
tenEcmCharts Displays charts of both real-time and historical ECM data.
Real-time Chart
Hourly Chart
Daily Chart
Monthly Chart
Average Hour of Day Chart
tenEcmCsvLogger Writes real-time ECM data to a CSV file
A set of ECM-12xx programs are now available:
Requires Windows and .net 2.0 frameworkCode:tenEcmServer Receives data from ECM and broadcasts it to the other programs tenHsEcm12xx HomeSeer plugin that creates devices that track ECM data, computes monthly cost, and charts real-time ECM data tenEcmDbLogger Writes hourly ECM data to an SQL database tenEcmCharts Displays charts of both real-time and historical ECM data. Real-time Chart Hourly Chart Daily Chart Monthly Chart Average Hour of Day Chart tenEcmCsvLogger Writes real-time ECM data to a CSV file
http://www.tenholder.net/tenWare2/tenEcmServer
tenholde
to use your charting and logger, do i need homeseer
(downloaded homeseer demo, but it keeps crashing my computer for some reason (or no reason, just for fun)
thanks
Thanks for all your great work on this tenholde, much appreciated (particularly from us non-programmer typesA set of ECM-12xx programs are now available:
tenholde
No, the HomeSeer plugin is just one of the optional clients. The only required component is the tenEcmServer. I am using Ed's stuff without HomeSeer and he has been very responsive to get things matured and fixed. Two thumbs up!to use your charting and logger, do i need homeseerA set of ECM-12xx programs are now available:
thanks
tenholde
Ed,
I want to thank you for the good work you have been doing with the software. It all installs nicely, runs great and looks good.
Paul
Ed,
Paul
Same here Ed. Thank you for your hard work. The server, plugin, and charting is working great!
Will
