KidCalledZero
I have been lurking for a while doing research on home automation and belive I want to purchase an ELM M1 to control my outdoor lighting and irrigation systems.
I have a couple question that I hope someone can answer before I take the dive and purchase the hardware.
My outdoor lighting is low voltage 12V and I will have 3 transformers located outside on three sides of my house. I want to be able to break my lighting into several zones per transformer and control each zone remotely through the M1 system. Ideally I would like to locate the M1 relays next to the transformers in weatherproof enclosures right next to the transformers and run each lighting zone from the relay box to the lights. I simply need contacts to open and close as the power will be provided by the lighting transformers. This brings me to my first question.
Can I remotely locate the relay boards away from the main M1 enclosure and if so, how far can I go and what type of wire is required?
This leads to my next question which involves my irrigation system. Assuming I can locate the relays remotely from the main M1 enclosure, oI assume I will need a 24V power supply to run through the relays to drive my irrigation valves or does ELK make a stand alone 24V irrigation control module or is there a 3rd party that does?
My final question is about interfacing with the M1. I would very much like to have a stand alone touch screen. Something larger than 3 inches. I see the the ELK touch screen has been discontinued. Are there other touch screens that will interface with the M1? I read that ELK is working on a ipad application but it isnt available yet. Do all touch pads require the use of a home ethernet network or do some operate directly with the M1?
Any help on these issues would be greatly appreciated.
Thanks!
Thanks!
