tmbrown97
OK. For the irrigation, if it's still home-run to one place, I'd personally put an M1XOVR and M1RB in the garage in a can (I used the 28" one that comes with the system) and run the irrigation directly off those relays. In my case I tied in another 12V power source to run everything else and put one of these in to distribute power and protect the circuits... I'd consider that for you too - so that you can use a single power supply to power all your exterior relays but if one of the three "legs" gets shorted, that would isolate it so it doesn't take out the other 2 or anything else running on that power supply.
For the lighting scenario, earlier I was under the impression you only had 3 zones - but this is a lot more complex - so I would definitely go the route of the double relays and do the exterior enclosures with the second set of relays. Sorry if this wasn't clear earlier - I only meant losing the double relays for the irrigation; since your others will be exterior, I'd absolutely double-relay them.
To answer some questions -
Also in an earlier post you asked how much could fit in a 14x14 enclosure - I started with a 28" in my last house with the audio amp (elk 124), ethernet expander, input expander, M1 itself, a DBH and a couple XSP's - and it got full fast. Here's a picture (yeah, I know - a total mess). For my current house I didn't screw around - I went straight for the 50" can directly above an existing 20" so I should hopefully never run out of space. I think the general rule for us DIYers is to go as big as you can. You might be able to make a 14" work but you'd be looking at mounting the boards vertically and keeping the ethernet module elsewhere most likely. Keep in mind - you don't have to go with the Elk can - but with most other can's you'll lose the UL rating if you care unless you use a can that's UL rated for residential security and use the specific odd bracket that they evaluated; though I think most of us just drill screw holes in the new can to fit.
- You can daisy chain in any scenario - even if you do Cat5 with the DBH... the instructions aren't the most intuitive, but if I had a manual in front of me I could describe it.
- You can use another power supply to power devices on the databus in the manner you described; but a couple of things (please - experts, double-check this) - you should definitely use a battery backup that will run the extension of the databus at least as long as the main controller - losing items on the databus causes all sorts of errors. Also, I believe you want to keep the ground reference the same so you'd want to tie the grounds together on each power supply.
