123
That configuration appears to be the one I posted here but with its topics modified for Omnilink.
That configuration is designed to work with my customized version of MQTT HVAC (i.e. the MQTT climate component). It's not the same as rsw686's customized version of the same climate component.
Unlike rsw686's version of the MQTT climate component, mine does not support separate 'target temperature settings for low and high'. Therefore it's not likely to work well for you. Conversely, the configuration you posted won't work with rsw686's version because it uses different options (like "activity_state_topic").
It's my understanding that rsw686 is submitting his modified version to become part of the standard MQTT climate component. The Pull Request is here. Once it is part of the standard release, there'll be no need for special instructions to install it as a custom component (like mine).
On the other hand, if you're just curious to see my version in operation (with the understanding that it lacks settings for low/high temperature targets), this post contains a link to the code and installation instructions.
For best results with omnilink, you'll need to wait for rsw686's version to be released with 0.89 compatibility.
