Sort of have done the same here with a from scratch build on my Armbian Ubuntu 18.04 64 bit box...using 0.92.0b1 which was the latest for aarch64 as of yesterday.
Just started HA with no edits to the configuration.yaml
and see log entries.
Unable to find services.yaml for the logbook integration
6:18 PM helpers/service.py (WARNING)
Unable to find services.yaml for the stream integration
Unable to find services.yaml for the script integration
Unable to load /config/known_devices.yaml: Config file not found: /config/known_devices.yaml
6:17 PM components/device_tracker/__init__.py (ERROR)
Docker OmniLinkBridge is not running nor installed yet.
Squeezeplayers show up with no edits here.
Installed docker OmniLinkBridge and started it...note nothing is configured in HA.
root@ICS-Pine64:/opt/omnilink-bridge# docker container logs omnilink-bridge
OmniLinkBridge.CoreServer: 2019-04-18 18:35:33,750 DEBUG: Starting up server 1.1.3.0
OmniLinkBridge.Modules.OmniLinkII: 2019-04-18 18:35:35,065 INFO : CONNECTION STATUS: Connecting
OmniLinkBridge.Modules.OmniLinkII: 2019-04-18 18:35:35,223 INFO : CONTROLLER IS: OmniPro II (4.0B)
OmniLinkBridge.Modules.OmniLinkII: 2019-04-18 18:35:35,235 DEBUG: Retrieving named units
OmniLinkBridge.Modules.OmniLinkII: 2019-04-18 18:35:35,370 DEBUG: Waiting for named units Area
OmniLinkBridge.Modules.OmniLinkII: 2019-04-18 18:35:35,432 DEBUG: Waiting for named units Zone
OmniLinkBridge.WebServiceModule: 2019-04-18 18:35:35,772 INFO : Listening on
%5Burl="http://0.0.0.0:8000/"]http://0.0.0.0:8000/[/URL]
OmniLinkBridge.Modules.OmniLinkII: 2019-04-18 18:35:36,304 DEBUG: Waiting for named units Thermostat
OmniLinkBridge.Modules.OmniLinkII: 2019-04-18 18:35:36,410 DEBUG: Added thermostat to watch list Thermostat 1
OmniLinkBridge.Modules.OmniLinkII: 2019-04-18 18:35:36,482 DEBUG: Polling status received for Thermostat Thermostat 1
OmniLinkBridge.Modules.OmniLinkII: 2019-04-18 18:35:36,544 DEBUG: Waiting for named units Unit
OmniLinkBridge.Modules.OmniLinkII: 2019-04-18 18:35:38,721 DEBUG: Waiting for named units Message
OmniLinkBridge.Modules.OmniLinkII: 2019-04-18 18:35:38,898 DEBUG: Waiting for named units Button
OmniLinkBridge.Modules.OmniLinkII: 2019-04-18 18:35:39,018 INFO : Unsolicited notifications enabled
OmniLinkBridge.Modules.MQTTModule: 2019-04-18 18:35:39,048 DEBUG: Publishing areas
Restarted HA.
Same log entries as above. No errors relating to temps et al.
Current base configuration directory shows:
root@ICS-Pine64:/opt/home-assistant/config# ls -l
total 284
-rw-r--r-- 1 root root 2 Apr 18 08:17 automations.yaml
-rw-r--r-- 1 root root 992 Apr 18 08:17 configuration.yaml
-rw-r--r-- 1 root root 0 Apr 18 08:17 customize.yaml
drwxr-xr-x 2 root root 4096 Apr 18 08:17 deps
-rw-r--r-- 1 root root 0 Apr 18 08:17 groups.yaml
-rw-r--r-- 1 root root 562 Apr 18 18:39 home-assistant.log
-rw-r--r-- 1 root root 266240 Apr 18 18:42 home-assistant_v2.db
-rw-r--r-- 1 root root 0 Apr 18 08:17 scripts.yaml
-rw-r--r-- 1 root root 157 Apr 18 08:17 secrets.yaml
drwxr-xr-x 2 root root 4096 Apr 18 08:18 tts
Personally delete or remove HA again and install it again.
