Here created a test output, updated and reconfigured the OmniLinkBridge via the HA GUI.
Note in HA instead of an INI file it is using a yaml file.
1 - in PCA created a test general output and labeled it test.
2 - in HA reconfigured the OmniLinkBridge - Rebuild
3 - in HA checked the configuration.
I do see an error in the loading of the HA OmniLinkBridge:
Add-on: OmniLink Bridge
MQTT bridge, web service API, time sync, and logging for HAI/Leviton OmniPro II controllers
Add-on version: 1.1.10
You are running the latest version of this add-on.
parse error: Expected string key before ':' at line 1, column 4
[08:36:56] ERROR: Unknown HTTP error occured
System: (amd64 / qemux86-64)
Home Assistant Core: 2021.7.4
OK it worked. Looked at all of the OmniBridgeMQTT stuff and found my test output button.
Created a toggle button using the HASS
ower button in a single card.
Tested it looking at PCA / Status. It works fine.
