jmorris644
rsw686 said:Joe,
The mySQL connection is only needed if you would like additional logging. I actually haven't tested it on linux with mono. However the mono project has information on setting up ODBC.
For MQTT you need a broker installed like Mosquitto. For OmniLink Bridge the bare minimal configuration would be to define he controller_address, controller_key1, controller_key2, mqtt_server and set mqtt_enabled to yes. The communication between the components looks like this:
Home Assistant <=MQTT Protocol=> Mosquitto <=MQTT Protocol=> OmniLink Bridge <=OmniLinkII Protocol=> OmniPro Controller
On the Home Assistant side you would add the following you your configuration.yaml
mqtt:
broker: localhost (or host/ip)
discovery: true
discovery_prefix: homeassistant
Thanks Ryan,
I am going to be using node-red to communicate with the Bridge. Can you give me a list of topics to subscribe to?
Joe
